Swap Questions
Old Nov 2, 2003 | 02:29 AM
SchwarzCamaroRS's Avatar
Swap Questions
Just wondering if this engine would fit into my 91 Camaro RS
http://www.sdpc2000.com/cart.asp?act...id=130&pid=383
Old Nov 2, 2003 | 02:46 AM
radiateu2's Avatar
Yes it would but would require a different flywheel/flexplate since you would be going form a 1piece rear main seal to a 2 piece rear main seal> Your current block is a roller ther one on the web site is most likely a non roller block. You would also need a dofferent intake due to the angle and configuration of the center bolts on each side of the intake. Do you plan to carb or use the FI on your car?
Old Nov 2, 2003 | 02:03 PM
I plan to keep everything the same, i was going to just use the stock throttle body.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
