350 Carb Questions
Old Nov 2, 2003 | 04:07 PM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
350 Carb Questions
So I'm swapping a carbed 350 in place of my old tired LO3, and I had a few questions....First, it came with a Holley 4160 (or 4150, I forget which...). It's a 600 CFM carb, which I'm imagining isn't NEARLY enough, but hey, it was free. I'm wondering which manifold I should use, Performer, Performer RPM, or either of the two in air-gap form. Also wondering about clearance issues, and how tall of an air cleaner I would need to clear. Hood cutting isn't an option right now.
Also, will my engine be completely suffocating with the 600 on it? Money's pretty tight now, but if it's absolutely necessary that I get a carb that breathes better, I guess I could. What size should I go with, at least? What would be ideal? What brand?
Thanks in advance!
--Rob
Old Nov 2, 2003 | 05:07 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Get a performer rpm. its a better hi perfprmance manifold.
It will fit under a stock hood with a old gm muscle car drop base aircleaner. You have to shorten or remove the choke horn on your carb to use this aircleaner. use a14x3" filter element.
You can buy the aircleaner assembly or just the special base from
http://www.noahperformance.com/
With this GM aircleaner the performer rpm fits under your hood with room to spare.
Old Nov 5, 2003 | 01:15 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
A 600cfm holley is enough to feed a stock (or close to) 350. If it's heavily modified a 750 would be better. If you're running an auto a 4160 style (vac secondaries, pn 3310 for 750cfm) is reccomended, for a manual a 4150 style (mech secondaries, pn 4779 for 750cfm) is reccomended.
Old Nov 5, 2003 | 05:44 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Go for the the Performer RPM Air gap, it worth the extra money. and a 600cfm carb should be fine for street & srtip
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
