LT1 running too cold, help!
Old Nov 3, 2003 | 09:41 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
i swapped in a 95 LT1. since the swap, it has seemed to run cold. now that i need the heater, this is true. i can drive it for long periods of time and it doesnt seem to heat up enough. the fan seems to come on way early. i replaced all the fan switches and all the sending units, and even the thermostat. what else can i do?
Old Nov 3, 2003 | 10:11 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Did you have the PCM reprogrammed? It may be programmed to have the fans come on at a very low temperature.
Old Nov 5, 2003 | 01:08 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Have you tried a warmer t-stat? Maybe a 195 or 210?
Old Nov 5, 2003 | 10:14 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Use a piece of cardboard to block part of the airflow to the radiator.
Old Nov 5, 2003 | 02:42 PM
sinner's Avatar
cardboard will work temporarily. i got the pcm from pcm for less. he was suposed to make it factory. i have an e mail into them to see what the problem is. i havent heard back from them yet. i havent tried a warmer thermostat, i camn tho if the pcm thing doesnt pan out.
should i remove the air dam?
Old Nov 5, 2003 | 03:22 PM
kfoley's Avatar
Car: '85 Z28
I wouldn't remove the air dam, it might make it too hot. Without it the radiator doesn't see much airflow.
Old Nov 5, 2003 | 06:01 PM
wm_sorg's Avatar
Removing the air dam is a bad idea
Old Nov 5, 2003 | 07:28 PM
sinner's Avatar
i think engine is at right temp, did some checking, heater is just cold. i know the heater core is ok. how does a guy hook up the heater control valve with this swap? maybe i have the valve going to the wrong nipples.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
