Lt1 Vats ?
Old Nov 3, 2003 | 04:58 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
Lt1 Vats ?
I have a LT1 from a 93 Z28 that I am going to put in my 89 IROC this coming year, i was wondering if the fuel enable signal to the 93 ECM is the same one my 89 VATS module puts out, if yes, can I just wire my 89 VAT to the 93 ECM? if it is different, I will just program it out
Old Nov 3, 2003 | 10:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
PM Dale, he's hooking me up w/a VATS bypass module for my swap. He should be able to answer your question as he did a complete 3.4 SFI swap in an S10 truck & had to deal w/VATS crap.
Old Nov 4, 2003 | 04:18 PM
mat89RS's Avatar
The 89 Vats module will not work because it's Passkey I, I have a spare Passkey II if you want it, 50$US.
Old Nov 4, 2003 | 05:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello mat89RS,
I beg to differ with you about the 1993 VATS modules. I have a 1993 VATS module and key sitting in front of me and they are the same part as what is in my 1989 Iroc. Besides, the ECM only looks for a signal from the VATS control module saying the resistance code is good. There are no codes for the VATS stored in the ECM, they are only stored in the key and the VATS control module.
The Trickster!!!!!!!!!!!
RS Reaper
Oct 17, 2018 07:52 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
AmorgetRS
Sep 28, 2015 09:33 PM
sahlomonic
Sep 20, 2015 07:15 PM
Winchester1094
Sep 15, 2015 09:48 AM
