CARB. to TPI
Old Nov 4, 2003 | 11:08 AM
X86TRANSAMWS6X's Avatar
Car: 87 Conquest TSI, 86 Fiero GT
CARB. to TPI
my Trans Am has a fried interior harness and a peiced back together engine harness. however, my car still run but some stuff does not work. i have always liked tpi for many reasons so i figure since im changin the interior harness why not switch to tpi. what else do i need to switch to tpi? besides the tpi setup. do i need the fuel lines too? if i used an external fuel pump how would i wire it up?
thanx
Old Nov 4, 2003 | 01:58 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I would try to find a wrecked TPI car. You will need fuel lines, ecm, and fuel pump complex for in the tank. I would replace it with a walbro fuel pump. You will also need a fuel pump relay etc. If you find a donor car, just take the whole harness.
An alternitive wiring solution for the fuel pump would be the racetronix harness. Check out www.racetronix.com It comes with its own relays, etc.
Old Nov 4, 2003 | 04:49 PM
thank man, thats wat i figured i was gonna have to do is buy a parts car. it is probably the best way to go.
thanks man
theshackle
Sep 17, 2020 08:26 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
tero
Aug 15, 2015 02:47 PM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
