70s 350 into 82 Camaro
Old Nov 20, 2003 | 06:57 PM
purple88's Avatar
Car: 1988 Oldsmobile Cutlass
Engine: 307 V-8
Transmission: 200-4R
I have the opportunity to buy a 350 out of an early 70s 1/2 ton Chevy pickup. I am looking at buying an 82 Camaro with a 305. The 350 should bolt in, shouldn't it?
Also, I can buy a TH-350 tranny that has 2 days on rebuild for $50. It came out of an 86 Chevy pickup. The Camaro has a three speed tranny (I'm assuming its a th-350). Will the pickup tranny bolt into the Camaro?
Thanks for the help
Old Nov 20, 2003 | 09:55 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Yep 350 will fit and so will the turbo 350 with the correct trans. crossmember.
Old Nov 20, 2003 | 10:35 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
the 82 car has a th200c. It is junk but externally identical to a th350. The only part you will need is a bracket to mount the torque arm to the tail shaft. I believe B&M makes such a bracket. Either way jegs has the part just give them a call.
edit: And yes the 350 is a direct bolt in.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
camaro71633
Sep 1, 2015 10:24 AM
