Fuel Pump Swap.....Quick Question...
Old Nov 26, 2003 | 09:56 AM
SweetRide45's Avatar
Ok, well, my question is, I'm changing out my differential soon, and I figure, since I'm at it, I might as well swap out the fuel pump. I have a '90 Firebird 3.1 mpfi. I'm also planning on swapping in a 350 TPI Crate from sdpc. And I want all the pressure that thing needs, w/o going back up to swap the damn pump out. Now, would my 3.1 go hay-wire w/ a V8 pump in there? I'd figure my stock regulator would still keep it at what my v6 needs, and it shouldn't be a problem.
Also, what is the best pump to get that would flow what the "Future" engine would need, and would last the longest and is most reliable? Any sites? I hear Walbro is pretty good, but you guys tell ME what would be the best bet.
Any info would be greatly appreciated.
Thanks!!!
Old Nov 26, 2003 | 06:29 PM
Doesn't anyone know about this?
Old Nov 26, 2003 | 07:28 PM
windowlicker's Avatar
Well, I can't positively answer your first question, although I would assume if the fuel regulator is working you will be fine.
For your second question check out this website:
http://www.racetronix.com/product/RX..._Pump_Kit.html
This is the pump kit almost everyone uses for LT1 swaps and should be more than adequate for a SB crate engine.
Old Nov 27, 2003 | 12:00 AM
Would I need that whole kit? All my wiring, etc. is fine to the pump. I'm talking about just upgrading the pump itself, not the relays, etc. etc. (unless you need new stuff for the new pump)
Old Nov 28, 2003 | 01:24 PM
No, you don't need the whole kit--I believe you can just order the pump from summit for about $125.00, if you go to www.summitracing.com and type in this part # GRN-GM722-2 it will give you the details.
Old Nov 28, 2003 | 04:55 PM
Ok, thanks for your help. Now, can anyone give a more positive answer on the V6 part of it? I would assume it would work fine as well, but I just want to make sure.
Thanks again.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
