Does l98 have mech fuel pump lobe??
Old Nov 28, 2003 | 07:44 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Ok, I've searched and searched and keep coming up with yes and no. Who knows for a fact that a 91Z L98 Engine has or does not have a mechanical fuel pump lobe? I am putting an L98 long block into a friends 85 Camaro(305) It has a mechanical fuel pump with a stock q-jet intake and a 600Holley.(yes its too big for the 305 but should be fine with the 350)
Problems... I'm sure I'll have to drill some of the intake holes because of the slight difference.
and I'm not completely sure the distributor gear will be compatible with the gear on the l98 cam.
Any suggestions on these areas?
PS. I have swapped many SBC's in the day. i dont need a step by step of the swap just the specifics which I stated above or any problems I will run into.Thanks a bunch................jt
Old Nov 28, 2003 | 08:17 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
my 1988 L98 has a fuel pump lobe. as for the dist gear you're 'supposed' to use a melonized steel gear. You can buy 'em at www.sdpc2000.com among other places. I ran a regular gear for over a year with a roller cam and had absolutely no wear on it when pulled but might as well be safe than sorry I guess.
Old Nov 28, 2003 | 09:10 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Thanks, I appreciate the help................jt
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
