crazy combo
Old Dec 2, 2003 | 10:39 AM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
crazy combo
I have a 1984 LG4. I recently purchased the special calibrator chip and ecm that went the zz4 conversion kit for my particular engine [24502457]. My question is what if I bought the LM1 Goodwrench engine 8.5 to 1 compression ratio with dished pistons 1971-85 retrofit 350 and added a performer intake manifold and performer rpm heads and finally a cam profile similar to or identical to the zz4 would the timing and fuel be to much. I would buy the rpm heads because they have no emissions like the zz4 corvette heads. ok go ahead and laugh me out of the message board.
Old Dec 2, 2003 | 12:42 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I didnt know you needed a chip to put a 350 into an original Lg4 car. My brother in law is running a 355 with the stock chip in his and it runs like a champ. I was told that all the computer controls in those cars is the timing, so you should be good with any mild 350, as long as it doesnt have a radical cam and compression higher than 9:5:1. It should work fine, but if your not on a tight budget I would just spring for the 350 ho that GM makes it would put out a hell of alot more power than the other engine. Good Luck.
Old Dec 10, 2003 | 04:09 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
If you're using the stock CC QJet then all the computer controls is the timing advance. A new chip would make the curve more agressive. You'll have to change rods (similar to jets in a holley) and set the AV tension to tune it to your motor. It's a good carb with some tuning.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
