LT1 Intake on a 406 SBC!!!
Old Dec 9, 2003 | 06:54 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
check this out. i can get a GOOD 406 sbc rotating assembly for 900 bucks then get an lt1 intake machined to fit on a small block for 400 bucks. with some new heads and a cam this should be one hell of a power monster to drop into my 1991 z. any comments, questions, or ideas here? think this is a good idea?
Old Dec 9, 2003 | 11:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
anyone? im pretty fresh to this and could use some help.
Old Dec 9, 2003 | 11:42 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I know there is someone on this board with a LT1 intaked 406, I can't remember who it is. From what limited knowledge I have of EFI the opinons on the LT1 intake swap are kind split. For the most part I think people like it. Obivously if you do this you will have to have a custom PROM burned. LT1 intakes will support upwards 500+ hp so I can't forsee it choking airflow like a TPI setup would, and is a hell alot cheaper than a S/R, mini ram setup.
Good luck
Old Dec 10, 2003 | 07:23 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Im in the process of doing a 408+cubes with twin turbos and Im either gona do a Lt1 or HSR.
I had a LT1 i converted an dpit on a 358 but ended up getting rid of everything befor I used it..
The only thing I dont like about the LT1 is the remote T stat.
Old Dec 10, 2003 | 09:06 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
true true but how hard is it to actually drop one in because of the remote t stat?
Old Dec 10, 2003 | 10:48 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Not hard at all... If I didnt have my LS1 or and actual LT1 I would go with an LT1 intake, L98 Aluminum heads with some work or some nice aftermarket alluminum heads and a cam... Your talking about a significant street car now making very nice power... Asuming your engine is already a TPI your not gonna have much trouble at all. The remote thermostat is just a housing to hold your t stat thats not on the intake because there isnt one on the actual LT1 intake, but you can mount the remote T stat anywhere in the engine compartment you want. Most people dont likei t for looks, but I dont think its that bad, and you can mount it wherever you want.
Old Dec 10, 2003 | 10:50 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool. i hope to find an engine to put this intake on soon
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
C409
Sep 23, 2015 04:30 PM
trevor1010
Aug 24, 2015 11:29 AM
sreZ28
Aug 14, 2015 07:48 PM
