Need axels
Old Dec 11, 2003 | 12:14 AM
lt1g3n's Avatar
Car: 1983 Camaro
Engine: Lt1 (383 project)
Need axels
I took out my stock rear end gears, and replaced them with posi gears from a 97 TA/ everything fits fine, but my axels use to be 26-spine, and this new one is 28 spline, so i went ahead and got myself some 28 spline axels, and they are fine, BUT... they are too long... so that means my breaks on the back wont work :P.. so any ideas on exactly what axels i need? Any part #'s or what not..
i know i need 28 spline, but i need them the length of the 83 camaro factory ones.. ;/
thanks.:lala:
Old Dec 11, 2003 | 12:56 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
what did you get the 28 spline axles out of.... You can get some out of a 90-92 f body, they will work.
Old Dec 11, 2003 | 01:00 AM
cdartz's Avatar
28 spline axles started in 89 or 90 I believe in thirdgens. Your 83 axle housing is not as wide as a fourthgen, so if you ordered 97 axles because you have 97 gears then that is why they are too long. Try ordering axles for a 92 housing. They should be 28 spline, but since it's still a thirdgen year they should be the correct length.
Old Dec 11, 2003 | 04:53 PM
lt1g3n's Avatar
Car: 1983 Camaro
Thanks ALOT!!
hectre13
Dec 11, 2023 08:14 AM
TBI89Formula
May 14, 2002 08:08 PM
1982chevycamaroz28
Feb 16, 2002 08:53 AM
UVA3rdGen
Aug 6, 2001 09:34 AM
AustinT
Feb 5, 2001 09:36 AM
