building a 383 need some help.
Old Dec 22, 2003 | 02:57 PM
1987-396-IROC's Avatar
Car: 1987 IROC-Z
Engine: 4 bolt 383
hey guys im having a shop biuld me a 383 and im running low on cash after its all said and done, and i was wondering if the stock rods would hold up in a 383 or if not whitch ones would be cheap to buy but still hold say 450-500HP. :confused:
Old Dec 24, 2003 | 01:10 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Stock rods *might* hold up if they're R&R'd w/ ARP bolts, but personally I wouldn't trust them. For about as much as working the stock rods you can get a set of 5140 forged rods (CAT $150 or Scat/Eagle $200) and those are ready to go with ARP bolts in them. They're good up to 500hp.
If they're one thing I've learned, don't cheap out on a motor. If you do it will be more exspensive in the long run when you have to replace whatever broke and everything it took along with it.
Old Dec 24, 2003 | 05:09 AM
ede's Avatar
ede
what stock rods?
Old Dec 29, 2003 | 08:58 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
There are a few "good" stock rods out there. I just sold a set of GM "x" rods that were forged. They have a X in the bottom. Otherwise spend the money wisely.
Old Dec 30, 2003 | 11:43 AM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Whats yoru copressio ratio and how high will you be spinning this joker? TEll us your combo.
Old Dec 30, 2003 | 12:58 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
A friend of mine with a 383 in an s10 is running stock 5.7" rods out of a 350, runs 117 mph in the 1/4 shifting at well over 7000 rpm. Some people are lucky, some arent.
Old Dec 31, 2003 | 07:57 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
If you use gm x rods or the new gm powdered metal rods, with good rod bolts they should hold for that much. Make sure the rods have been properly inspected for cracks and such. Also, as said before, new aftermarket rods, ie. scat, eagle, will be a good investment. If you are going to scrimp and save on a motor, please don't do it on the bottom end. Do it up top where it is easier to get to and repair. Just my 2 cents.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Jorlain
Oct 8, 2015 01:57 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Numbah-1
Sep 12, 2015 08:57 PM
