trick flow ?
Old Dec 26, 2003 | 06:41 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
trick flow ?
im buying a set of trick flow G2 heads my ? is how much horsepower will i gain with a good 3" exhaust headers and the G2 heads on a stock engine except for all the bolt on stuff i have?
Old Dec 26, 2003 | 07:21 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
if your ripping heads off, i sure as hell hope your tossin in a cam.... would be a waste otherwise, and i would expect to see minimal gains otherwise.
btw my setup is below, they are the 64cc 23* kenny dutweiler heads, cnc chambers...
Old Dec 29, 2003 | 09:43 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
What motor are they going onto? Like fb said, you won't see much gain if you don't replace the weak (I'm guessing it's stock) cam that's in it....
Old Dec 31, 2003 | 05:35 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
That's not entirely true. I've read two articles where the heads were swapped onto an otherwise stock engine and the gain was between 40 and 50 horses. One article dealt with Trick Flow, the other was AFR. These swaps were on a 5.0 Mustang, which has a slightly more aggressive cam from the factory, and a way better intake and EFI system, so I wouldn't expect gains like these, but I wouldn't be suprised if you picked up 20 horses or more.
Obviously a cam swap, and some intake work are really required to wake up the motor, but if you can't afford it the heads by themselves will still make a noticeable increase in power.
Old Jan 3, 2004 | 10:26 PM
C h r i s's Avatar
I looked into a set of G2s that were for sale... turned out they were really G1s after I called Trick Flow with the part number.
Just a heads up,
Chris
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
RS Reaper
Sep 27, 2015 07:04 PM
