LT1 heads????
Old Jan 25, 2004 | 02:37 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
LT1 heads????
Hey guys i was woundering would there be a problem with puttin LT1 heads on my 305, they have 1.94 int and 1.50 ext valves, there ported, 3/8 studs, 5/16 guid plates and have been machined for double valve springs, there cast iron heads by the way. What do u guys think??? i just want the heads
heres whats in my friends ad "2 steel LT1 heads, ported, machined to fit dual valve springs + port matched intake manifold machined to accept 58 mm throttle body. 1.94 intake valves and 1.50 exhaust valves, 3/8 rocker studs, 5/16 guide plates, springs, locks, retainers included. Heads and intake have about 2000 miles on them since ported. Intake is green ceramic painted. Flow numbers included below: Barometer: 29" Temperature: 88 degrees Lift Intake Exhaust .100" 53.94 50.46 .200" 111.20 102.70 .300" 160.70 145.24 .400" 200.20 174.79 .500" 225.65 190.71 .550" 233.57 195.42 .600" 241.23 200.02 .650" 241.23 200.02 .700" 241.23 200.02 Price includes ground shipping in continental US. Reason for sale: Ran out of money to complete this project. ***Note, I do not know spring pressure... I forget what I used. ***Price mildly negotiable"
Old Jan 25, 2004 | 03:16 AM
TexasLT1's Avatar
Car: '92 RS
Yes there is a problem, it can't be done. The reverse cooled LT1 heads cannot be used on a traditional SBC due to the different coolant passages. On the LT1 the heads are cooled first whereas on a traditional SBC the block is cooled first. Also, I'm not sure but I think the valves might be too big for a 305 because of the smaller bore.
Old Jan 25, 2004 | 10:30 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
well, without modifacation it cant be done, look up TPI_ROC, hes welded chunks of aluminum in the passages...very nicely done..
and 194 150 will be fine in a 305 head...people have done 202 150 on 305's,...just takes a little more chamber work
Old Jan 25, 2004 | 10:31 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
https://www.thirdgen.org/techbb2/sho...hreadid=178262
theres the link to his thread
Old Jan 25, 2004 | 12:12 PM
TexasLT1's Avatar
Car: '92 RS
Ok, I knew it was close on the valves. Thats awesome someone was able to modify them. Thanks for the correction f-crazy.
*Edit* Wow, thats incredible. I just went through and read the post. Awesome work by TPI_ROC, definitely should open up some avenues for other people.
Old Jan 25, 2004 | 03:54 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
when i go back CC im ditching the LT1 shortblock...gonna get a roller SBC all forged internally, with my LT4 heads...
what has to be done to run the LT1 motor on batch fire (730 ecm)
Old Jan 25, 2004 | 09:36 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay, this was just a thought becuz my friend is buildin a 383 stroker for his caprice with a blower on it and he just couldnt use these heads. im glad i asked before i did anything stupid. now i know another fact. thanx guys it was worth the question.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
