Engine Identification
Old Aug 21, 2015 | 02:26 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
I am putting an LT1 in my 86 IROC, and was told the engine I purchased was from a 97 Camaro. Most of the identifying marks agree with that but the heads are 1996, and it has a vented Optispark. Was the dealer correct in telling me it is a 1997 engine?
Old Aug 23, 2015 | 05:28 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Engine Identification
Model years begin in august, so yes you can get a 97 that was built in summer of 96. Parts surplus and shortages lead to minor year change overs. For the most part, 96-97's were the same so whats the problem?
Old Aug 23, 2015 | 06:54 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
I am looking for the PCM pin out diagram for this 1997 engine. Are the 96 and 97 the same in those PCM connectors? So I know what to look for. Thanks
Old Aug 23, 2015 | 07:12 PM
Pocket's Avatar
Car: 91 Trans Am
Google it, cant think of a more common search
94-95 are OBDI, same pinout
96-97 are OBDII, same pinout as prev, but a few pins added
Old Aug 24, 2015 | 08:35 AM
rdmotors's Avatar
Car: 1989 RS with T-Tops
Engine: 2.8L TPI Swapped to LT1
Transmission: 7004r auto Swapped to 4L60E
Axle/Gears: Stock Swapped to 3.27 Posi 9 bolt
Doing a 97 Firebird engine in my car I found that shbox.com is the best for the diagrams. Do watch thou some of his diagrams show for a 95, you have to do a lot of rechecking and digging to make sure you get it right.
Old Aug 26, 2015 | 05:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by Redwhisper
... and it has a vented Optispark.
Do you mean vented to atmosphere, or has the vacuum/fresh air purge?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
