building new 350. got 2-3k
Old Jan 26, 2004 | 01:35 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
ok I thought I knew what I wanted but now I don't know. Toss out some Ideas for me in the 2-3k range. I was interested in building a 383 stroker but *shrug. I have the '76 350 block already. was thinking about the comp cam 12-238-2 kit and a set of magnum roller tip rockers. and the headman shorties 68470. New distributor and oil pump etc. Heads I'm not sure yet... that kind of depends if I go with the stroker or not. Would like 10:1 or 11:1 compression. I've already got the carb and intake. 750CFM edelbrock performer combo.
So please point me to what is doable for preferably around 2k including machine time for block cleaning, bearing pressing, and head deck milling. Unless you think I can do the bearings and cleaning myself easily. Thanks a bunch in advance :-)
Old Jan 26, 2004 | 01:37 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
rebuild it to 355
vortec heads
XE274 cam/1.6 roller rockers
over 400HP .....12 second time slips
85 Jimmy
Sep 30, 2015 07:56 AM
Amillionoh7
Sep 26, 2015 09:45 AM
lethaldomestics
Sep 21, 2015 01:18 PM
apie2546
Sep 20, 2015 01:03 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
