Tell me if this sounds stupid...
Old Jan 27, 2004 | 04:18 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I have been planning on a 4th gen dash swap come spring break when I can take the car off the road.
What I'm wanting to do is knock out several brids with one stone.
1. I want the dash wiring to be as painless as possible.
2. I want better fuel economy.
3. I want to be able to tune my car easier (read: flash chip, not burn)
My idea is to get the complete underdash harness to use with the dash, a complete engine harness and try to convert my TPI MAF based batch fire system into a MAF based SFI set-up. This way, I won't have any issues getting gauges to work and I can get rid of that rats nest of a wiring harness under my dash (I think I found 3, that's right, 3 alarm boxes under the dash )
It this even possible? The only thing I see giving me problems is the whole optispark vs. my current CC dizzy set-up.
Can you put optispark on a standard SBC? Is there a better alternative to Optispark? Did my dealer sell me some bad crack? who knows.....
Ok, any critisms are welcome along with helpful advice.
What other obstacles do you see coming my way?
BTW, I currently have a SBC w/ a HSR setup and a 700R4 which will hopefully make way for a T56 sometime this summer.
Old Jan 27, 2004 | 04:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Tell me if this sounds stupid...
The dash idea is cool but the opti is not. The optispark is a piece and was quickly desinged for clearnace issuses upon the release of the 4th gen cars. Most people want to convert back to a distributor who have LT1's. It would cost an arm and a leg to change plus it is easier to change proms than it is to reprogram your ECM all the time. If you went to an optispark set-up you would need to completely change your front accessories including your water pump and timing chain and a whole slew of other mods. It is not worth it to spend money on an inferrior set-up.
Old Jan 27, 2004 | 04:40 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
How about keeping the CC dizzy and swapping to SFI?
Old Jan 27, 2004 | 06:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I don't think that can be done. Why do you want SFI so bad. Sure it is a little bit better but the standard TPI set-up isn't that bad.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
