sound any good?
Old Feb 3, 2004 | 07:06 PM
no_car_yet's Avatar
sound any good?
i have been looking for a 406 for a while now and i found this...sound like a it could be a good setup?
406 Short Block(TRW forgedpistons, 5.7 forged rods with ARP waveloc bolts,stock crank,.030 over 400 block 0 decked).GM 40 camshaft.Fresh rings and bearings. 750 USD
i thought that a 406 should have 6" rods?
Old Feb 3, 2004 | 09:58 PM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
The 5.7" rods will be fine in a street motor. If your were looking to build a 400 to spin up to or past 6000 rpm then I'ld go with longer rods and lighter pistons.
Old Feb 4, 2004 | 07:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Stock 400 rods are 5.565". So that 400 has "upgraded" ones.
Never heard of a "GM 40" cam. If it's any of the typical GM cams, such as the 929 or 151, it's garbage.
"406" is not a separate engine combo, like some unique hybrid of swapped parts or something. It's merely a 400 that's had the first routine maintenance performed on the block. It doesn's deserve some special designation. The "355" crap you see all the time falls into the same category.
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
BurlyChev
Aug 16, 2015 09:08 PM
mustangman65_79
Aug 8, 2015 12:07 PM
mustangman65_79
Aug 7, 2015 09:55 PM
