76 oil pan, in 89 Camaro
Old Feb 6, 2004 | 12:09 PM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I want to know if I can use the stock oil pan off a 76 block, and put it in my 89 camaro??? I don't know if it will hit anything, or whatever it will do if it doesn't fit. Thanks
Ty
Old Feb 6, 2004 | 02:19 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
not if your engine block is an 89 (or any 80+ for that matter)
Old Feb 6, 2004 | 02:32 PM
snowman89's Avatar
Engine: 5.8L 355
No, its the 76 block. I knew my 89 pan wouldn't work on the 76. I just wanted to know if the 76 block with its pan, will work.
Old Feb 6, 2004 | 02:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on what chassis it came from.
If it's out of a F, G, or A body (Camaro, Monte Carlo, Chevelle or the equivaents from other GM divisions) then it will.
If it's out of a full-size car, a truck, or a van, probably not.
Old Feb 6, 2004 | 04:26 PM
snowman89's Avatar
Engine: 5.8L 355
Its off a 2wd 76 truck, and if it doesn't fit, what one would???
Old Feb 6, 2004 | 04:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old Feb 6, 2004 | 05:00 PM
snowman89's Avatar
Engine: 5.8L 355
Allright, I'll look around junk yards or something and find one from a camaro...thanks
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
