Need help fast just swapped engine
Old Feb 10, 2004 | 10:06 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
I just got done with all the wiring and hooking everything back up. except the vacuum line on the vapfr. tried to start the motor and nothing. we get alittle hiccup but nothing that big. we have spark. the timing set right at the #1. and close enough to get started and tune. but the car won't fire. any suggestion. sort of need some answers fast need the car back on the road. here are some of the motor specs.
350 bored .020 over 10.22CR , ported 441 heads, Large valves 2.02/1.60, Weiland 7547 intake, Crane Pro Magnuim Roller Rockers, 454 TBI, headers from dynomax, crane ingnition, tbichips made me a chip to work with the 454 injectors, 80lb injectors, w/ vafpr.
Bullet racing cam based on the Lunati 501A3LUN
duration @ .050
int. 218/exh 218
int .510/exh .510 lift
112 sep, 106 c/l
3 btc 35abc
47 bbc -9atc
__________________
Old Feb 10, 2004 | 11:16 PM
droppedgmc's Avatar
Car: 2000 sierra, 86 camaro
sounds like the distributor is 180* out
Old Feb 10, 2004 | 11:29 PM
Car: 1992 Camaro RS
yes there is fuel alot of fuel that would be the 80lb injectors. we took the distributor off and checked the it and we were off by one at first fixed it and also do the finger trick. everything was lined up and nothing just a very little hiccup.
Old Feb 11, 2004 | 10:36 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Pull a plug to see if they are fouled. Do you smell fuel when you crank it? How is the fuel pressure? Recheck all grounds and connectors.
Old Feb 11, 2004 | 10:48 AM
Car: 1992 Camaro RS
plugs are not fouled only turn over 5 or 6 times. checked the plugs there good. don't smell it but can see the fuel. not sure on the pressure but it spraying alot of fuel and a good spray pattern. I remember connecting 3 wires on the back of the passenger side head one on the front passenger head i think those are the only ones that took of the engine. if anyone has anything else let me know.
thank again
Old Feb 11, 2004 | 01:53 PM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
Check your timing. I could of swore my timing was correct on #1. But it wouldnt fire, it wasnt 180 degree's out either. I was finally like okay screw this, and loosened it up, started moving the cap around a little bit, and it fired.
Old Feb 11, 2004 | 07:34 PM
Car: 1992 Camaro RS
got it running. it runs ok. running open headers and no o2 sensor. very loud. getting the fixed tommorrow. the timing was off by about a 1/8 turn. and since it wasn't firing it was flooding the engine. thanks for all your help everyone.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
