383 stroker kit
Old Feb 14, 2004 | 04:49 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
383 stroker kit
I am now looking at buying this stroker kit and wondering what you might think of this set up. As far as flex plate goes do I use the 153 or 168? This will be going into an L98 block with Vortec heads. All opinions are welcomed, here is the kit:
CHEVY 383 ci EAGLE STROKER ROTATING KIT!! This auction Includes all new parts! No recut cranks, No blems! And this kit has been balanced and is ready to install!!!
Eagle ESP Cast/Steel 3.750" Stroke Crankshaft (external balance) 1 or 2 piece rear seal
5.7" 5140 steel SIR bushed rods with ARP bolts (SIR5700BBLW), (these are the new cap screw design!) these rods have been clearanced for up to a .600 lift cam!
Keith Black KB135 Hypereutectic Pistons 9.7 compression with 64cc head or 9:1 with a 72 cc head (Part # KB135) .020,
.030, .040, .060
Premium Moly Ring set (E251K.)
Clevite 77 Main & Rod bearings
Professional Products 8" External damper
Pioneer 153 or 168 flex plate!
Assembly has been balanced
Old Feb 17, 2004 | 01:34 AM
apinaire's Avatar
Car: 84 berlinetta
Engine: 383
Transmission: 700-R4
i would use the 168 tooth because of the higher compression, and the torque it will take the starter to crank the engin.
Old Feb 17, 2004 | 07:14 AM
86z/92rs's Avatar
Thanks for the reply.
Old Feb 19, 2004 | 09:09 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
The 168 tooth flywheel is what I'm using and you will need to get a 400 sbc starter. And your flywheel cover won't fit anymore. Just thought I'd help ya out.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
sleprock
Oct 1, 2015 09:39 AM
buckshot63
Sep 10, 2015 09:15 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
