just bought an engine
Old Feb 22, 2004 | 11:38 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Not sure this belongs here, since I'm going from LB9 to LB9?
I am going to be getting a new engine for my TA next week! I ended up buying a 305 tpi complete from a 92 Z28 with 35000 miles. Got a good deal even though I was hoping for a 350. Can't wait to take my first drive of the season!
Anyway, I've never pulled the engine before. I'm going to have some help, so that's a plus. Just wondering if there is anything special to keep in mind, any hints. I'm going to take lots of pictures before I start, and I have the factory manual which has already been very handy. How long should I plan on the swap taking? I was thinking of setting aside 2-3 days the 2nd week of March.
_________________
Old Feb 23, 2004 | 05:06 AM
ede's Avatar
ede
i'd drain the coolent somewhere i'm not pulling the engine, then move the car to where you're pulling the engine. it'll keep you from laying in coolent. watch for ground straps.
Old Feb 23, 2004 | 09:13 AM
kevinc's Avatar
Car: 1982 Z28
Buy several boxes of Ziploc bags and a Sharpie magic marker. As you remove a component, put the bolts & whatnot into a Ziploc and write the component name on the bag.
Sounds stupid, but you'll be glad you did during reassembly.
Use masking tape and the Sharpie to label all wiring connectors and vacuum lines so you know where they go later.
Old Feb 23, 2004 | 06:23 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
pull the radiator out just to be safe from puncturing it, it may take a little longer , but it could save you a lot of money
Old Feb 23, 2004 | 08:23 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yes definatley pull the radiator, its only 6 small bolts and its a cinch to do, six bolts will save you a lot of trouble and give you piece of mind.
Old Feb 23, 2004 | 09:13 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
might want to get some thick towels for the fenders in case the engine happens to swing that way...if protecting the paint is a concern of yours. Also drain the trank and drop the diff when you change the pump. Will save you time fighting to get the tank out and aggrivation. I thought I could get the tank out with the diff in place and spent forever fighting with it, and I had the use of a lift. Replace the motor mounts while you have the engine out, I'm sure this is something you've already thought of but just in case.
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Sep 7, 2015 01:37 PM
johanlindgren
Aug 16, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
