383 Build up
Old Mar 3, 2004 | 05:36 PM
firefrombelow's Avatar
383 Build up
What can I do to get a 383 to push 500hp? Im on a buget, and I want to do a budget build up...Probably no more than 10.5:1 compression....Just ask if you have other questions...
Thanks alot:cheers:
Old Mar 3, 2004 | 06:03 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
you`ll need to make like 1.4 or something close to achieve that 500 horse number, I wouldn`t concern yourself on total horsepower, those number are always peak and aren`t useable on the street anways...build your motor to make peak torque at a normal rpm level that you`ll see in everyday driving. Build your engine to make torque...the horse will follow! I`m doing a 383 now we are hoping to pull 475 ft lbs of torque on pump....were useing 11.1`s 6.100 long rods, solid street roller and afr`s 195 heads, should come close to 500 ponies too.....lotsa $$$ will get you to your goal every time
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
