LS conversion question
Old Mar 7, 2004 | 07:51 PM
3ZZZ's Avatar
Can the 02 a/c compressor work on 3rd gen. conversion or would it be better to use the 3rd gen a/c unit.
I am putting in 02 ls6 into an 82 z28.
The other post says you have to modify the lines. Is that becuase it is an LS compressor or 3rd gen compressor?
Old Mar 7, 2004 | 08:18 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
You would need to notch the K-member to get the compressor to work.
There is no way around that. unless of course you are FlyNLow, his car has a custom bracket to use the stock 92 compressor on his LS1. ThirdGen Resource did it. I will let him tell you more about it tho.
Old Mar 7, 2004 | 08:28 PM
3ZZZ's Avatar
Flyn2low,
Were are you! I was also thinking about getting a bracket that put the compressor high on passenger side.
But are we talking about using the stock one or ls1?
Knyghtmare thanks for your post..
Old Mar 7, 2004 | 09:53 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Hey no problem.
He used the stock 92 Compressor...
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
