Moderaters please place
Moderaters delete please
Moderaters please,If you can post a list of links to help.
I'm thinking of motor swapping 90, 305 TPI into my a 3.1 92rs
The motor,if I buy it will have trans,ecm
I need to get the wirring out of another car because they chopped it off and all I will ger is the fire wallforward.
What problems will I face?
Things I know,
motor and trans.mounds
Crossmember
subframe connectors
rearend
How can I use my factory gauges (oil,temp,SPEDO,rpm,amp)?
Things I know,
Crossmember
subframe connectors
rearend
Transmission: 4L80E/4L80E
Welcome aboard.
If you do a search on this forum for "V6* swap" (you need the "*" because the search function requires 3 characters), limited to title only, you'll get a page full of links that will contain all the info you need.
The best info is contained in threads to which I've responded...
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Welcome to TGO man, good luck with the swap. The V6 -> V8 swap topics come up a few times a week, so there should be alot of good info here.
Pac J
May 17, 2020 10:44 AM
