New Car, might have had motor swapped, need help identifying...
Old Mar 22, 2004 | 04:45 PM
Dapht Punk's Avatar
Car: 1987 Camaro
Transmission: TH 350
Hey folks,
I picked up an 87 Firebird. The vin say Formula 305, but a few things are making me wonder if maybe somebody swapped the engine.
Where should I check for identifiers? I know the VIN number is on the engine, but I have no idea where to look
Wouldn't it be nice to find a 350 lurking under there heh...
Old Mar 22, 2004 | 05:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I suppose we can assume it's a V8.
The VIN/serial number are stamped on a pad on the block in front of the passenger side head. The pad is the same surface as the head gasket surface. It's under the alternator, and the easiest way to see it will probably be to remove the alternator. If the block has been "decked", the numbers are probably gone. If the block/engine is a factory replacement, there will only be a s/n, which won't be of any value determining the engine size.
The block casting number is located on the bellhousing casting behind the driver's side head. Of the two, I'd go for the casting # (even though it's a bear to see with the engine in the car).
Now, about your avitar...
Old Mar 22, 2004 | 05:35 PM
Dapht Punk's Avatar
Car: 1987 Camaro
thanks!
As for the Avatar, I'm a web developer by day, so it's kind of fitting in a way. I'd much rather have one of the guys from Office Space, but I didn't see them in the list
Old Mar 22, 2004 | 06:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They are out there. I have seen a few people on other boards with them.
I would also check the head casting numbers as well to see what they are. If the engine was swapped it could be put together with a whole slew of parts.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
hokis
Aug 9, 2015 03:57 PM
