ls1 swap how did you guys wire these things up??help
Old Mar 22, 2004 | 07:51 PM
redtail2624's Avatar
Car: 88 TA
Engine: 383 Converted LT1 intake
Transmission: TH350 3500 stall
Axle/Gears: 12 bolt 3.73's
putting an ls1 in a 87 trans am and we have the harness that goes to the ecm already on the motor but how do we wire this computer in with the rest of the car and tie it all in with the fuse box.What did everyone else do besides spend lots of money on a custom harness.let me know how you guys got these ls1's wired up to your cars.any help would be great.
Old Mar 23, 2004 | 09:53 PM
kevinc's Avatar
Car: 1982 Z28
I bought an '01 Helms, used my '82 Helms, and fabricated a harness to connect the LS1 harness to the '82 chassis connectors.
'82 chassis pinouts are not same as '87 so my pinouts are not any help, but you can use the same process cheaper than buying a custom harness.
You may not even need to get the Helms, hit the Conversion and Hybrids forum on ls1tech.com and find the recent post where some guy said his local library had a subscription to some service that got him printouts of the LS1 wiring diagrams. Wish I'd known of that earlier, I dropped almost $100 on the '01 Helms books.
If you can get the diagrams and connector pinouts, you just need junkyard connectors, wire, and plenty of Metri-Pak pins from NAPA or a friendly GM dealership parts dept to do it my way. I snagged a chassis harness from a '99 V6 F-body on eBay for $40, it had everything I needed except for the new Metri-Pak pins.
BRoss99
Aug 10, 2025 05:08 PM
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
reiderz iroc
Aug 13, 2015 04:57 PM
