questions on swap
Old Mar 30, 2004 | 12:33 AM
86birdy's Avatar
Car: 89 Firebird Formula
Engine: 400+ hp 350
Transmission: turbo 350
questions on swap
i just got a 89 formula and after tearing the heads off i found a whole the size of a softball in the piston chamber, so im gonna swap the engine for an older 350 with a carb. the engine that was in it was a 84-90 model 350 with a fuel injected carb, the previous owner told me that it wasnt the orginal engine and he didnt know what it was out of. my question is if i do away with the fuel injection is the computer needed for anything else or can i just take it out all together? also if i do this would i be neededing a wire harness for the older 350? thanks
Old Mar 30, 2004 | 08:40 AM
kevinc's Avatar
Car: 1982 Z28
Re: questions on swap
"Piston chamber" ?
"Fuel injected carb"?
Old Mar 30, 2004 | 04:27 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you have to decide whether or not you want to use your stock distibutor, fuel pump, and trans if you have an auto.
also i think the speedo needs the computer to work.
with out the computer youd have to get a different distibutor, wire the fuel pump to a switch and relay with a regulator, and the 700r4 needs a vac operated lockup switch to function properly
getting a different wiring harness can help some but i did my own.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
