lt1 in an 84
Old Apr 5, 2004 | 12:24 AM
dnchevyman's Avatar
Car: 79 z and 84 z
Engine: 383 in 79 and 84 lt1 383 in 84
Transmission: t-10 in 79 and 700 t4 in 84
lt1 in an 84
does anyone have a step by step instruction source for putting an lt1 into an 84 z28?
also, will the stock fuel injectors be good enough for a 383 stroker lt1??
email-dnchevyman@hotmail.com
Old Apr 5, 2004 | 07:29 AM
TexasLT1's Avatar
Car: '92 RS
Welcome to the board. No, there is not a step by step guide anywhere that will show you exactly how to do every single part of the swap. You can check this post at the top of this board for nearly all the information that you need. In the coming weeks I will be finishing up a detailed swap guide that should give anyone just about all the information they need, but it is not step by step either. The search button in the top right of your screen will lead you to just about everything you need to know for the swap.
*Edit* If it is a mild 383, stock injectors should be fine. If it is built to put out any kind of decent power at all for a 383, no the stock injectors will not be fine, you'll want to get some 30 lb injectors.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
