lt1swap 5V ref.
Old Apr 23, 2004 | 11:47 PM
  #101
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
Cool i'll check it out
Old Apr 24, 2004 | 06:10 PM
  #102
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Programmed computer with Tunercat
pretty easy to program out vats and stuff, didn't play with any maps yet.
Final mounting for the pcm will be the pass side where the evap can would be. I unbolted the plate that the evap can sits on and mounted it there. I will have to extend the wires about 8-10" but I see no other way. It isn't that big of a deal. I'll get some pictures someday.. Right now the car is on standby.. The TelCo that I work for has just gone out on strike .. so I'm busy there.
Old Apr 25, 2004 | 02:00 AM
  #103
z91bowtie1's Avatar
Engine: 96 LT1 5.7
would i be able to plug up the out let line under the throttle body? i'm using my 3rd gen radiator and there is know where to hook it up. the drivers side hose does not have the line going to the throttle body. and also the inlet and outlet heater hose's are opposed of the 3rd gen (my 91) right. sorry about the job
Old Apr 25, 2004 | 09:55 PM
  #104
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Told ya bud, get a 93 Z28 upper hose and it already has the fitting for the throttle body on the radiator hose. What you can do alternatively is do the throttle body bypass:
http://shbox.com/1/tb_bypass.jpg
Old Apr 25, 2004 | 10:19 PM
  #105
z91bowtie1's Avatar
Engine: 96 LT1 5.7
i bought a 93 hose and it was too short i went to three auto parts and nothing. so i bought an adapter and connected throttle body outlet to heater outlet. what do you think. did you get your car runing?
Old Apr 25, 2004 | 10:37 PM
  #106
pasky's Avatar
Whoah, how can it be too short? Let me go outside right now and i'll take a picture.... Engine is running perfectly. I just put the transmission in but tourque arm, hydraulics, and driveshaft are not hooked up.
Old Apr 25, 2004 | 10:59 PM
  #107
pasky's Avatar
Picture 1
Old Apr 25, 2004 | 11:01 PM
  #108
pasky's Avatar
Picture 2
Old Apr 25, 2004 | 11:02 PM
  #109
pasky's Avatar
Picture 3
Old Apr 25, 2004 | 11:03 PM
  #110
pasky's Avatar
Picture 4
Old Apr 26, 2004 | 12:13 AM
  #111
z91bowtie1's Avatar
Engine: 96 LT1 5.7
the one i bought looks now where near like the one you got. it was a short hose. didnt even have that smaller hose with it.
can you take a pic of your heater hoses. i'm gone try napa or car quest next. he man and your headers are they shortys, long tube. how do they fit? what brand are they?
Old Apr 26, 2004 | 12:36 AM
  #112
pasky's Avatar
Thats a 93 z28 Upper radiator hose and 93 z28 lower radiator hose, I got them from O'reiley's. Maybe he gave you some 93 v6 hose.
The headers are SLP 1 5/8" w/ 3" collector's shorties. Drivers side clearance was fine, went in without problems.
It was the passenger side that took me almost a day to get in because no one carried any 3/8 x 1" bolts and I had to use some hex bolts and the very back bolt of the passenger side was almost impossible to get to.
Old Apr 26, 2004 | 01:16 AM
  #113
z91bowtie1's Avatar
Engine: 96 LT1 5.7
that's what i figured it had to be for some other engine. I explained to them what i needed and thats what there computer showed. thats what i get for going to auto zone
Old Apr 27, 2004 | 11:50 AM
  #114
pasky's Avatar
Ever find the right hose bow tie?
Old Apr 28, 2004 | 02:25 AM
  #115
z91bowtie1's Avatar
Engine: 96 LT1 5.7
Yea man went to napa yesterday and picked it up today. did all the pluming work today looks real nice so far. I took the dryer out to see if the pcm will fit there and it looks pretty good in that spot. Turned my car on so a friend of mine can here it and when i hit the throttle it shut off so i guess i got to mess with the dam vats.
Old Apr 29, 2004 | 03:23 AM
  #116
z91bowtie1's Avatar
Engine: 96 LT1 5.7
got my delete wheel and it's on. i don't think i hook any thing to the vats plug do i have to and where is it? i'v looked for a 16 pin conn. and nothing. what about vats is there something i can buy to over ride it or do i just take it some where and get it done.
Old Apr 29, 2004 | 07:50 AM
  #117
pasky's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
These come with a lifetime warranty. I'd rather program it out but this is an alternative.
Old Apr 29, 2004 | 11:24 AM
  #118
z91bowtie1's Avatar
Engine: 96 LT1 5.7
i'll look in to it. what about vacume lines did yoy have to hook any up?
Old May 1, 2004 | 02:14 AM
  #119
z91bowtie1's Avatar
Engine: 96 LT1 5.7
I went to the chevy dealer and they told me they could not delete vats. he said the only thing they can try to do is match my key with the pcm but i have to bring my car in. i told them the car was apart he told me that all they can do. i also called around and nobody can do it. so i ordered the bypass maybe that will work. any thing on the vacumes
