What does everyone think of my setup, Im building?
Old Apr 8, 2004 | 06:35 PM
firefrombelow's Avatar
Displacement: 383 cu. in.
Carburetor: Mighty Demon 850
Heads: Air Flow Research 210cc, with 2.08/1.60 in. valves, CNC porting, and extra hand-porting
Intake: Edelbrock Performer RPM
Camshaft: Comp Cams hydraulic roller, with 235/242° of duration @ 0.050 in. of lift, and 0.555/0.576 in. of lift (Corrected valve lift with 1.6:1 rockers is 0.592/0.614 in.)
Rockers: Comp Cams 1.6:1
Pistons: Ross Forged
Rods: Eagle 4340 Forged H Beam rods
Crank: Eagle Forged 4340
Timing: 36°
Comp. Ratio: ~10.5:1
What do yall think????
Old Apr 8, 2004 | 07:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you were looking for a way to put more pieces in your T5 & 10-bolt, I think you found it...
Old Apr 8, 2004 | 07:44 PM
Nope......TH700R4 and 12 Bolt
Old Apr 9, 2004 | 07:21 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
IF i would point out one wrong thing, is your intake. I would go with a Victor Jr. intake to take full advantage of that big cam you are running. You are going to need a high stall, and you power band will probly start around 3000 or so, so if i were you, go with a victor. Most of the time, they make more tq. and Hp than a RPM. Just ask around tho, its just what i see. Worth probly about 15 hp and 10 ft lbs.
Old Apr 9, 2004 | 10:49 PM
Thanks for the suggestion....
Bubbajones_ya
Jul 6, 2024 08:32 PM
86Firebird86
Dec 26, 2015 07:21 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Jorlain
Oct 8, 2015 01:57 AM
Ranbo108
Sep 9, 2015 12:20 PM
