Quick question on intakes????
Old Apr 13, 2004 | 11:15 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Okay my friend has an 86 firebird with a 350. edelbrock performer intake (not sure if its a rpm airgap or what but is a performer style) and he blew his motor a few weeks ago. i got him a deal on an 87 gta with a stock l98. can he use his edelbrock intake on the l98 heads? i was told no by the master tech at work, i believe him but i want more info on this. i looked in jegs at the edelbrock intakes and it just says the sizes of the motors the intakes can go on. doesnt say anything about years or head styles.
so if you can shead some more light on this that would be great but if it wont fit i guess we'll be swappin heads on the l98 with the ones off of his 350.
Old Apr 13, 2004 | 11:55 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm not sure but aren't the bolt patterns on the '86 and earlier different than the later models?
Old Apr 14, 2004 | 04:50 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thats what i think and thats what my friend told me. but jegs doesnt list any years that the intake will fit on , it just list 262-350 sbc.
Old Apr 14, 2004 | 05:00 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
There is the vortec bolt pattern, and the old bolt pattern. Intakes are made for 262-400 SBC. The 87 probly has the "Vortec" style bolt pattern as the 86 has the regular style.
Old Apr 14, 2004 | 07:10 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can modify the intake bolt holes to work. Is this a carb intake? I take it you would be converting the L98 to carb?
Old Apr 14, 2004 | 09:50 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah the bird is carbed and were goin to take the l98 and swap the carb on there but i told my friend we might have to swap the heads most likly so we're prepared to swap heads if need be.
Old Apr 15, 2004 | 12:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally posted by chev496
The 87 probly has the "Vortec" style bolt pattern...
Not hardly. The Vortec pattern started in 1996.
As Shifty said, you can modify (elongate, specifically) the center two bolt holes on each side so you can get the 72 degree bolts into the head. There are also '87-up Performer (EGR style) and '87-up Action + (non-EGR) available.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
