Fuel Injected V6 to Carb V8
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
Okay, the 5.7 V8 is fully rebuilt, the tranny is rebuilt, they're both mounted in the car, and i'm trying to hook it all up. My question is whether or not I have to do something special to hook up the fuel system to the carb. From what i've seen and heard, there is an electric fuel pump inside the tank. The plug for this is just above the differential. If I just disconnect this plug, will the fuel still pass through the pump straight to the carb without trouble such as being stopped at this electice pump?
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
That will work. In fact, some of the earlier thirdgens came with a mechanical pump and the in tank electric. Mine came with both being a L69 originally.
What most would probably suggest is to keep the in-tank electric and use a 3 port preasure regulator to regulate the fuel preasure to 5-7psi for carb. The three port reg will send the extra fuel back to the tank via the return line. This will keep the pump from straining too much.
The other option is to drop the tank pull the pump off and put a piece of tubing in its place to make a carb fuel pickup and just run a mechanical on the block.
Car: '89 Firebird
Engine: 7.0L
You're Firebird came with a high pressure pump for the original fuel injection system suitable for the power of your V6. However, at low pressure, where a carb operates, that same pump will provide more fuel than you can use. Instead of hacking up the fuel system I would use what you have. All you need is a fuel pressure regulator (from Mallory sold through Summit Racing) and an AN fuel adapter kit (sold through Summit Racing) to go from your stock flexible fuel lines in the engine bay to AN fittings and some extra line to go to your carb. The Mallory pressure regulator will have a port to return extra fuel to the tank and allow you to connect a fuel pressure gauge. It's an exotic fuel system for a non-exotic price!
Just unplugging the electric pump may or may not work. When i did the swap it didn't. I couldn't pull anything thourgh the old pump. A regulator is the way to go, dropping the tank is a pain.
Thats basically what I was saying. The easiest way would be to run a regulator with a return, but I gave the other options also.
The sock was probably clogged on your electric pump.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah droppin the tank is a pain in the ars .....but i couldnt find a cheap enough regulator with the 3 ports on it myself i was on a budget and we just dropped the tank but if you do drop the tand be prepared to bust some knuckles and say a couple dirty devils while your down there its a real pain ...lol.
RedLeader289
May 28, 2019 01:47 PM
Damon
Sep 26, 2015 04:29 PM
