Aircon Delete-now what belt?
Old Apr 22, 2004 | 03:34 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Ive just installed my ZZ4 in place of my 305TPI.Ive also deleted the aircon and now ive ended up with two belts,both having to be tensioned with the power steering pump.This is almost impossible as the two belts have to have the exact same amount of slack in them to enable them to be tesioned together.Has anyone else come across this problem and can you fit an idler to sort it out
cheers
PM
Old Apr 22, 2004 | 03:48 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
My alternator mounts top drivers side, and I have another mount on the passenger side that mounts the A/C, AIR pump and a spring loaded tensioner pully. (see photo). I'm in California, so I can't delete the air pump or the smog ***** will beat me with a dead cat.
Maybe something will give you an idea...
Troy
So Cal
Old Apr 25, 2004 | 01:57 AM
TexasLT1's Avatar
Car: '92 RS
Troy
So Cal
You have serpentine, he has V-belt, doesn't help much.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
