1974 engine in 89 tpi need little help projrct practicly over!
Old Apr 24, 2004 | 12:09 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi im gonna tell you my new setup and tell me if i forget something because like lot of people know here i broke a brand new engine while installing it(leaking injector causing bending 2 rod) so before to turn the key what else sould i check? now my engine is...350 1974 overbore of .030 that give something like 355 think so. stock 1989 lb9(305) heads, speedpro flat top forged piston, crane cam 480 480lift 232 232 duration @ .050
lsa 110,flat tappet/200lbs after makket spring retainers. headers,muffler,still running stock tpi system with 95 LT1 injectors
and after the engine in gonna turn im gonna send chip to Brian Hearter some guy in state that i heard good thing about him. but i dont know what plug should i run 305 89/350 1974??? witch sensor???
can i run my car without knock sensor??? and about the engine to transmission the engine is made tu run a 14in of total diameter flywheel ans my old 305 13inch flywheel dont fit 74 crank. and the starter dont fit too. help me
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
