LT1 swap question
Old May 11, 2004 | 02:40 PM
Traderartie's Avatar
Car: 87 Iroc
Engine: Carbed LT1
LT1 swap question
Is it possible to run a '93 harness and pcm on a '94 motor ?... I noticed that the '93 takes a chip and the '94 does not.. Which is better ?
Also, how can you tell if a pcm is bad ? I cant get any spark with the '94 pcm..
Thanks, Artie
Old May 11, 2004 | 02:42 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Nope not possible. The 93 uses the ECM style computer used in our thirdgens, 94 is a PCM which uses re-writable flash memory. IMO the PCM is the better design but others will argue because its easy to pull a chip out of the 93 and burn your own. Its all personal preference. As far as the no spark. Check coil, plugs and most importantly opti.
Old May 11, 2004 | 02:48 PM
Car: 87 Iroc
Engine: Carbed LT1
It wont work even if im using the 93 computer also ?
thanks, Artie
Old May 11, 2004 | 02:55 PM
pasky's Avatar
Not sure, the 93 computer used batch fire injection, not sure what else was changed, Oh the 93 is speed density also. Will probably work but the 94 will be the better choice.
Old May 11, 2004 | 07:34 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
It will work just fine if you use the 93 computer and harness, there is also a difference with the TPS connector, otherwise its the same. However i'd rather use the 94-95 setup anyway.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
