lt1 swap. where to run wires to starter?
Old May 12, 2004 | 11:05 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Where is everyone running the wires that go to the starter and knock sensor etc? I tried running them in front of the pass header and down along the block with the plug wires but it just doesn't go right and i was worried about heat getting to the wires..
then i tried putting them in loom and running them between #6 & #8 header pipes, centered with the dip stick, but the loom melted.
any ideas?
Old May 12, 2004 | 03:31 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I used stock routing for the main starter power wire, and used the stock thirdgen purple starter wire.
Old May 12, 2004 | 03:41 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
where was the stock routing?? I had mine apart for so long, I couldn't remember
Old May 12, 2004 | 03:58 PM
91Z28-350's Avatar
stock routing is on top of the block, between the valve covers and intake manifold, then it loops down the front of the block and comes back around hugging the block. There's a clasp on the block that holds the loom close to the block. The loom contains the injector wires, the IAC motor connector, A/C, knock sensor, and the starter wires.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
L98GTA87
Aug 5, 2015 11:02 PM
