500 inch Caddy into 89 'Bird
Old May 19, 2004 | 07:40 PM
LS1Formula's Avatar
Car: 1989 Firebird
Engine: Toilet Bowl Injection 305
Transmission: Autotragic
So I've got a pair of 500 cid Caddy motors. One is a 70 high compression, the other is a 74. I plan on using the 70 heads with the 74 short block in order to see about 9:1 compression. An aluminum performer intake and Comp 268H should round out the combo. Anyway, does anyone have info on doing the swap? I can't find anything anywhere on this. My immediate concerns are the motor mounts, front clearance, and transmission cross member location with a TH400. Any help would be appreciated.
Old May 19, 2004 | 09:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Try a search for 'big block in a 3rd gen"
Old May 19, 2004 | 10:57 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
Do a search of this forum, IIRC someone here has already done the 500 cad swap.
Old May 19, 2004 | 11:07 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I believe he also removed a nice chunk of his firewall for better weight distribution too.
Old May 19, 2004 | 11:20 PM
LS1Formula's Avatar
Car: 1989 Firebird
Why would he do that? With an aluminum intake they're within 20lbs of an iron head small block Chevy.
raymondandretti
Sep 27, 2015 06:43 PM
monte87cortez
Sep 26, 2015 08:10 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
