lt1 swapped, which supercharger can i use?
Old May 26, 2004 | 05:41 PM
bluepastu's Avatar
Car: 87 vert
I'm at 10.5:1. Which supercharger can i use and how many psi? I want to stay with the 93 octane . thanks
Old May 26, 2004 | 05:44 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
1/2 psi... 10:5.1 is pushing it already you can get away with about 11.1 compression on premium with alumium heads... AND good computer tuning
Old May 26, 2004 | 05:45 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Think you can use the procharger, not sure though because almost all the lt1 chargers use a mount on the drivers side that looks like it would hit our steering boxes. Best thing to do is call ATI up and ask them which setup would work
Old May 26, 2004 | 08:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You can use a powerdyne kit for the impala SS, it is available in 4.5 and 6 psi form, your other choice is vortechs universale carb'd sbc kit, which you will need to have a crank pulley fabricated, unless you get lucky and an LT1 piece happens to line up.
midge54
Sep 2, 2020 07:13 PM
midge54
Jan 29, 2017 07:00 PM
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
sreZ28
Aug 14, 2015 07:48 PM
