V6-V8 Throttle Cable, Fuel Line Fitting Sizes?
Old May 26, 2004 | 04:51 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
MPFI V6 to Carb'd 350 V8. What do I do about the throtle cable, and what size fittings are on the 2 fuel lines that are next to eachother? Is one of them metric?
Old May 26, 2004 | 07:06 PM
ljnowell's Avatar
Dont exactly remember the size of the fittings. I have just finished the exact same swap (2.8 mpfi > carbd 350) and I found it easy to move the fuel lines to the passenger side of the car. The holes are already there piece of cake (this is because I was using a mechanical pump) but if you are using an electric pump, this isnt important to you. As far as the throttle linkage, I used the stock v6 cable with a universal throttle bracket from summit on an edelbrock intake and carb, and everything hooked up perfect.
Old May 26, 2004 | 07:08 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
the throttle linkage cable will have to be bunched up a bit at the firewall but it will work flawlessly
Old May 26, 2004 | 07:13 PM
ljnowell's Avatar
gee general you would think that the two of us have done it before!
Old May 26, 2004 | 07:31 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Any other little things I should know about? Once I get the fuel reg hooked up everything is done and ready to go...finally...
Old May 26, 2004 | 07:55 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I'm almost done my swap. The linkage isnt hard at all. I used a throttle bracket like ljnowell said, Get some braided fuel line for the line going from the afpr to the carb.
Depending on what wires you removed your fp may or may not come on. I only removed the crap i didnt need. I left the ecm and most wires, i also wired in the ops to help aid in powering the pump.
Did you get a fuel pressure gauge?
Heres where im at, i cant post pics so heres the link
www.cardomain.com/memberpage/611873
Old May 26, 2004 | 08:43 PM
Car: 1988 Camaro
Engine: 350 V-Eight
All my wires are still there, im only gonna remove the ones i dont need after im all done. Should i put a fuel guage on? or just use my uncles to set the pressure then take it off? cuz how much are they?
Old May 26, 2004 | 08:48 PM
Car: 1988 Camaro
Engine: 350 V-Eight
And anyone know the sizes of those fittings?
Old May 26, 2004 | 09:19 PM
THEGENERAL's Avatar
i would just borrow your uncles gauge for now
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
AkDrifted
Aug 17, 2015 07:45 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
