LT1 starter wire ?'s
Do I simply connect the yellow wire from my LT1 harness (which comes from the firewall directly to the starter) to the purple wire coming out of my firewall(for the starter)? I thought the signal had to first go the the computer for the VATS to work properely.
Thanks, Matt
Thanks, Matt
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If its a f-body harness, one of the c100 connectors off the lt1 harness is a thick purple wire that needs to splice into your thirdgen c100 purple wire. Not sure about other model lt1's.
db057
Aug 11, 2015 10:11 PM
