oil dipstick
Old Jun 11, 2004 | 01:50 PM
86z28stroker
Guest
Posts: n/a
oil dipstick
Does anyone know where I can get an oil dipstick for an 86 camaro.
Old Jun 11, 2004 | 02:07 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Auto parts stores usually have chrome replacements. Auto Zone, Advance, Napa, and Pep Boys. It's a good idea though, when you install it to change your oil and after start-up check the level with a fresh 5 qts. and check to make sure the oil is on the full mark. If it isn't, mark the full level on your dip stick so you know where full mark is with a dremmel or small file.
Old Jun 11, 2004 | 02:31 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
also, where you want to take a reading from, if its smooth, rough it up with some sandpaper or a file.
the rougher surface allows the oil to cling at the level and not slip off..... letting you read it easier.
Old Jun 11, 2004 | 03:03 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
I don't mean to hijack your thread
what if you put 5 quarts in and it dosen't even read on the dipstick? I don't want to overfill it or underfill it
Old Jun 11, 2004 | 03:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: I don't mean to hijack your thread
then the dipstick is too short. lol.
what he was saying is:
put a known about of fluid in... inotherwords, drain the motor, then add in the reccomend amount... in the case of our SBCs its 5 quarts.
then, onces its settled, put the stick in, and where it registeres is where you mark the full line.
after that, you use the stick to check it.
Old Jun 11, 2004 | 04:40 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
If the dipstick is to short, head to the local bone yard and get a longer one! The tube is what you want in the first place, right? I assume your replacing it because the old tube is broken
Old Jun 11, 2004 | 04:47 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
actually its the dipstick tube off the lo3 which is now on the lo5 which is in my car. I suppose I could just shorten the tube some, the other problem with that tube is I have to wrestle the dipstick to get in there.
Old Jun 11, 2004 | 04:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't use those Mr. Gasket ones, they are a PITA. The tubes never fit in the block right. At least, not on the 3 I tried on my '79 350 block.
Old Jun 11, 2004 | 05:26 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
So, the tube your using now has got a pinch in it?, right? that's the only reason I can think of that would cause it to go in PITA.
Old Jun 11, 2004 | 05:31 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
yeah there's a pinch in it, it was a pain to get on there though, I don't really want to change it. what kind of motor would have a longer dipstick? or could I just cut the tube so its shorter?
Old Jun 11, 2004 | 10:19 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Measure your dipstick and head to the wrecking yard and start pulling dipsticks till you find one long enough. If you start cutting the tube you'll send metal shavings into the pan, you don't want to do that! Or you can go get an after mkt. tube at the auto part's store. Just tell the guy behind the counter it's for an LO5 and you should get the right one. cool?
Old Jun 11, 2004 | 11:22 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
I also saw "universal" dipsticks, apparently they just need cut to the right length. would using a tubing cutter still get metal shavings into the pan? I just don't want to have to pull off the exaust manifold, then wrestle the dip tube out (then installation is the reverse of removal ). anyway I'm not that concerned about it, I'm pretty sure that the motor doesen't burn oil; hopefully.
Old Jun 11, 2004 | 11:33 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
In that case just find a longer dipstick! shouldn't be to hard to find at the bone yard! Good luck and update what you find ok?
Old Jun 17, 2004 | 01:39 PM
kevinc's Avatar
Car: 1982 Z28
Re: oil dipstick
From an '86 Camaro.
Old Jun 27, 2004 | 11:28 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
i know at advance they have a "universal" dipstick. its fairly long and has a ring on it that you tighten when you get the desired length. its not the most gorgeous thingin the word tho....
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
