1987 L98 swap
Old Jun 18, 2004 | 07:49 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
1987 L98 swap
I have a 1987 Iroc with 5.7(124K) and a small oil leak. I debating between a complete rebuild of this engine or a new crate engine. My question is will the stock tpi system bolt up to a ZZ4 or Fast Burn 385 without any problems? How about the 290HP long block that Scroggins Dickey sells? I have also located a couple of 1985 Corvette L98's that I could rebuild and swap in. Will the 1987 tpi system bolt up to those? My ultimate goal consists of 350-400HP and 400(+)ft/lbs. I have a co-worker that runs 13.7 in a untuned Honda CRX that I would love to walk consistly. I don't have to worry about emissions but I would like to keep the tpi setup.
Thanks in advance
Old Jun 18, 2004 | 08:40 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
I almost forgot, the other option is the 350 tpi engine from goautocenter.com. I'm sure with a little work that engine could get close to 350hp.
Thanks again
Old Jun 18, 2004 | 01:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Your probably gonna have to leave TPI outta the mix if you wanna go over 300hp. Its just to restrictive for that kind of power. I wouldn't bother with those older Corvette L98 motors, but maybe find out what heads they have. I know some L98 Corvette motors had aluminum heads, and that would be a nice upgrade on your L98. Those Corvette motors ('85) aren't roller blocks like yours though, so keep yours.
Old Jun 18, 2004 | 02:31 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
That's one thing I was hoping to find out. Thanks.
lt500r55
Sep 1, 2021 01:30 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
Hello, Michael
Aug 20, 2015 03:19 PM
TheExaminer
Aug 19, 2015 10:07 PM
