fuel pressure difference from tpi to carb
Old Jun 21, 2004 | 12:29 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
i am swapping a carbed 355 into my 85 trans am that originally had a tpi 305...
you have to lower the fuel pressure from 40-something down to like 5-7psi for the carb right?? (running the electric fuel pump) and whats the best way to do this? --The 25 dollar regulator from Jegs???
any help would be great,
thanks
Old Jun 21, 2004 | 05:00 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You have to get a regulator that allows the excess fuel pressure to travel back into the return line.
Old Jun 21, 2004 | 09:09 PM
onebinky's Avatar
Yep, that's the easiest way to do it. When that goes out you could get a low pressure hi flow pump to replace it.
MustangBeater20
Oct 29, 2022 09:20 PM
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
