big block guys with a griffin.
Old Jun 28, 2004 | 12:31 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
What lower rad. hose are you running? part number or what it is for? I can get my stock cut v-6 one to work, but it will be tight. Please chime in. Also, what is your temp running at, along with what kind of fan/fans you are running.
Old Jun 29, 2004 | 10:43 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I have the 2 row 1 1/4" row radiator from Griffin.. 160 t-stat, dual flexalite 220 pullers, umm...dunno the part # on the lower rad hose, can probably check later when I get home.. I had to cut it to make it work w/the new radiator (it was too long).
Runs about 190-200 at night and about 200-210 during the day in about 90 degree heat.. I dont drive it too much when its hot outside..
Old Jun 29, 2004 | 01:09 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
ouch.. 210 is still to hot for me. I want no hotter than 190.. right now, she will get up to 230 going down the road, and i am very scared at that temp. do you have a big block or a sbc? may have to run different hoses.
Old Jun 29, 2004 | 01:10 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
505 bbc.
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Aug 14, 2015 08:25 PM
sreZ28
Aug 14, 2015 07:48 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
