hole for fuel pump swap
Old Jul 5, 2004 | 11:04 AM
jeffers42's Avatar
Car: 1985 camaro
Engine: 1971 355
Transmission: 5-speed
What would be the best way to seal up the hole in the hatch area after taking out the fuel pump in the tank. Do they make a something for that or is it something one has to create on their own.
Old Jul 5, 2004 | 11:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is no hole in the hatch area for taking out the pump. It's a non-issue. You drop the tank to change the pump.
Old Jul 5, 2004 | 12:28 PM
Drakar's Avatar
some members have "made" holes in the floor to access the pump easier, do a search for it, most people do as RB says. Drop the tank .... easier in the long run.
and no hole in the floor
Old Jul 8, 2004 | 09:21 AM
ljnowell's Avatar
Well, if you cut the hole out for the fuel pump change instead of dropping the tank, you might as well just junk it, you've already done enough damage.
Old Jul 8, 2004 | 11:46 AM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
Cover it with a flame retardant floor mat!
Seriously, this can be dangerous. One mistake away from a really bad situation.
I hope you find a way to fix this safely. No Joke!
Old Jul 8, 2004 | 03:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You've asked this on enough forums that I don't think we need to continue it here, especially since it isn't really engine swap related.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
