Will a 4th gen FP fit thirdgen?
Old Jul 15, 2004 | 10:23 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Will a 4th gen Fuel Pump, outta a '94 Z28 fit my stock L03 tank? What kind of modifications will I have to do?
If not, will the '94 Z metal tank fit in my '88 T/A? I'm doin' this for the LT1 swap.
Old Jul 16, 2004 | 08:59 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
No. But there are some aftermarket pumps that supposedly can be used in 3rd gen, abnd 4th gen tanks.
Old Jul 16, 2004 | 10:01 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
any pump intended for TPI in our cars can supply the LT1 with the proper fuel pressure and volume.
Old Jul 16, 2004 | 11:03 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Well the thing is, that I got the 4th gen tank with the engine, and I'm just wondering if it's possible to use the 4th gen tank or pump.
So ya'll are sayin' I should just get the TPI pump unstead? Will the TPI pump install into my TBI tank and be a direct hook up?
Old Jul 17, 2004 | 04:03 PM
TexasLT1's Avatar
Car: '92 RS
You can use the 4th gen tank and pump if you already have it. If you want to keep your 3rd gen tank, use a TPI replacement pump
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Casey Meyers
Mar 2, 2016 10:46 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
3rdgenparts
Aug 5, 2015 11:57 PM
