Can anyone Help?
Old Jul 17, 2004 | 10:10 PM
TA2514's Avatar
Car: 1988 Trans am
Can anyone Help?
I am building a 350 to put in my 1988 Trans am. I am looking for a 4 bolt main block that is a 1987 or newer block so I can use the hydraulic roller lifters in it. I was reading up on intake manifolds and some of the intakes for sale said they were made for 1986 cast iron heads or older and 1955-86 Chevy small blocks. I am looking for alluminum heads to put on my 350 block and I came up with a few questions. If I buy a 1987 or newer block and after market alluminum heads will the intakes that say they are made for 1986 or newer cast iron heads work? I know it sounds a little confusing but does anyone understand my question? Thanks for the help.
Old Jul 17, 2004 | 11:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Either type of heads will bolt up to either type of block.
The intake needs to match the type of heads.
Old Jul 18, 2004 | 01:34 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As far as the intake goes, the only difference between the 2 are the pre-86 intakes (and heads, for that matter) are all 90° mounting bolt holes. The 87-up heads/intakes have a slight variation. The center 2 bolts on each side are angled at 72° rather than the standard 90°. Other than that, there is no difference in port matching, etc. With an electric drill you can "massage" these 2 center bolts on a pre-86 intake so it will match the 87-up bolt pattern. Not too tricky.
Old Jul 18, 2004 | 08:51 PM
TA2514's Avatar
Car: 1988 Trans am
Thanks for the Help
