Out with the computer
Old Jul 18, 2004 | 03:37 AM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
I live in the wonderful state of Oregon where once a car reaches 21 years there are no more inspections for smog or any thing else...any thing is now possible. I would love to rip out my stupid computer on my 84Z and all of the other performance robbing junk. Once the computer is out, what items will not work that may have to be changed or adjusted? thanx, Ed.
Old Jul 18, 2004 | 03:05 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The carb and the dist. wont work properly w/o the ecm. The CC q-jet is fine for most of the stuff youll want to do and it wont rob you of power. Why not just remove teh AIR and the other things that really get in the way and leave the computer intact?
Old Jul 19, 2004 | 06:52 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i would suggest after market carb intake and dist. but if you do not want to spend the money. the carb will work with out the computer but will not be very adjustable. you can get a 70's hei distributer(the one without the wires sticking out) from the junk yard for cheap. i ran my car this way for a while. it ran a couple of tenths faster though it may be miss tuning of previous ign system.
if you do get the junk yard dist make sure to replace cap+rotor. you can get upgrade coils and modules from summit or jegs.
Old Jul 19, 2004 | 07:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the carb will not work without the computer, it will run obscenely rich.
Old Jul 19, 2004 | 09:06 PM
ljnowell's Avatar
Old Jul 19, 2004 | 10:25 PM
Drakar's Avatar
keep the computer till you really starting getting into it, then get a nice new billet MSD and a demon carb or holley or what ever floats your boat.
But as dimented24x7 mentioned get rid of the real smog crap first then the computer can go last.
Old Jul 20, 2004 | 12:22 AM
Car: 84Z & Porsche
Out with the puter
Well I have the jest of all that was said. First all of the clutter goes so I can get to and change the plugs....then it's onwards and upwards. I may run the computer a little longer till the 350/385hp arrives. Thanks for all, Ed.:yourock:
Old Jul 20, 2004 | 04:50 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
i ran my car this way for two or three years, if it were rich or lean i would have seen an increase in ET not a decrease.
ljnowell what does HM mean
Old Jul 20, 2004 | 04:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No you wouldn't. The WOT mixture would be unchanged but it would be rich at idle and part throttle.
Old Jul 20, 2004 | 05:07 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
ok, i didn't drive it very much mostly on the track so i guess i may have never noticed or cared much as long as the times didnt go down.
Old Jul 20, 2004 | 05:32 PM
ljnowell's Avatar
Im trying to figure out how the HEI distributor wouldnt have any wires coming off of it. It does, look at one.
Old Jul 21, 2004 | 04:28 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
cc hei's have a 4 wire plug coming off the dist.,im not talking about the two wire plug that is common to both types
Old Jul 21, 2004 | 04:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's easier to just identify it by the presence of the vacuum advance can.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
