LT1 Fans
Old Jul 28, 2004 | 03:31 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
LT1 Fans
Hey guys, I am finishing up putting an LT1 in my 89 RS. I am just using the 1 fan but the LT1 had 2 obviously. So I just wired my fan to the primary relay and it works fine. But now I am throwing a check engine lite with a code for the 2nd fan relay? Have any of you guys come across this before? or do you just have the #2 fan deleted from the PCM? By the way it is a 97 LT1 and PCM.
Old Jul 28, 2004 | 04:09 PM
ghettosmurf's Avatar
Car: 89 Camaro
Transmission: A4
sry i cant help you on the code, ....but how was the swap. have you driven it around yet???let me know, i am contemplating the same swap
Old Jul 28, 2004 | 04:38 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm doing the exact same thing, but I'm not as far along as you. I, however, am thinking of isolating the cooling fan relay, and wiring it to a switch, and eliminating them both from the PCM. Think this will work?
Old Jul 28, 2004 | 04:41 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I deleted my 2nd fan, programmed the 1st one to be "always on". No problems, car stays at 211* in 104 degree heat down here.
Old Jul 28, 2004 | 04:58 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
I drove it briefly last nite. But Couldn't do too much I found that the alternator isn't charging the battery. So the alternator might be junk. I also have to bleed the power steering system. Other than that it's driveable just have to put some small things back together like hanging wires and such.
Pasky Thanks for the reply I might just have to have it deleted out then. I have the fans come on pretty early so it stays nice and cool. PLus I have a 160 t-stat.
Old Jul 28, 2004 | 05:07 PM
pasky's Avatar
Im using a 190* thermostat. Im sure you will have better results than me. Replace your radiator cap while your at it.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
